I just Bought A Ford F250 2004 With a 6.0 and would like check and see if it has had any problems.
The vin number is 1FTNW21P04EA64463
Thank you in advance I really do respect what yall do for people
Again Thanks
Any Luck???
Is anybody doing these reports anymore?
I bought a truck with extremly low miles and have a little concern that it may have spent alot of time in the shop.............
it has had the following replaced.... 2 vgt's, 2 fuel manifolds, a/c work, belt tensioner, steering sector, pitman arm, clean center rotating housing on turbo, alternator, 4x4 motor and switch, egr valve and icp sensor. no open recalls
Thanks
would like to say thank you for the report......and when you say vgt are you talking the whole turbo or just the switch? but any ways thank you again for the much needed info.
according to the history it had the the vgt solenoid replaced. whole thing!!!
