I was driving and my OD light started flashing, speedo, odometer and cruise control quit operating. I was in a major rain storm today, did something get wet? Truck is running fine. Thanks in advance, John
MAFIA MEMBER 106
its probably the speed sensor on the rear diff there about 30 bucks get one from ford they fail but first check the conn @rear end
Discussion Starter · #3 ·
just replaced the sensor, Still flashing. Disconnected the batteries for a couple minutes and check tranny fluid, still flashing. Any more ideas apprieciated. Thanks, John
Former Ford AutoTrans Eng
The ONLY way to know what's wrong is to read the code that's stored in the PCM.
Without the code all you can do is buy parts and install them until you get lucky and find the problem.
Mod Friendly Title
Whack your gauge cluster. Seriously. Same thing happens to my truck when it is humid out. I give the gauges a good whack, and they start to work. Oh, you've gotta be stopped when you do it too.
Discussion Starter · #6 ·
Replaced VSS that wasn't it, Everything dried out and all is good again. Thanks for any help offered. Sixpack
