Could I get an OASIS for 1ftnx21f2yee19062?
Thanks
OASIS RESULT:
1FTNX21F2YEE19062
See bottom of the OASIS result for contact ID
02/07/2006
17:35:55
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2000 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/04/2000 BUILD DATE
06/09/2000 SALE MILEAGE
00231
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
BEFORE REPLACING 7.3L DIESEL TURBO PEDESTALS (-6N639-) SEE TSB 04-20-02
WARNING MESSAGES
LESS THAN TWO DEALER APPROVED AWA REPAIR VISITS PAID TO DATE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0764 - EXPIRED
STANDARD DEDUCTIBLE: 0 USD
OWNER NAME: DANNY MCDANIEL
OPTIONS:
EXPIRATION DATE: 08/04/2002
DISTANCE: 36,000
RENTAL: 28 UP TO 3 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 01075
ESP CONTRACT START DATE: 08/04/2000
REPAIR HISTORY
08/26/2005
DEALER: Berglund Ford
WARRANTY CLAIM NUMBER: 314908 ODOMETER: 045049M
LABOR OP
CONDITION CODE
CONDITION DESC
E9TZ 7086B GASKET-TRNS HOUSING 001 7003B 42 DOES NOT OPERATE PROPERLY
E7TZ 7086A GASKET-TRNS HOUSING 001 7000E
XT 2QDX 004 MT7086
7000 TRANSMISSION ASY-AUT 000
ADDED DYE FOUND LEAK AT EXTENSION HOUSING. REMOVEDTRANSFERCASE AND REPLACED GASKET TO CORRECT CONCERN.
END OF OASIS REPORT FOR 1FTNX21F2YEE19062
1FTNX21F2YEE19062 T/F7 F T/BD T/BD T/E A1 T/DQ T/DS 09-JUN-2000 04-AUG-2000 121680 USA 21 * * * * * * * 13936
AWS Claim Key: 15934573 Trx Code: 01S24 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 07518 - * Name: GAFFNEY FORD Ph: 864-4894764 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:11-APR-2002 Doc #:04111751
Cust Comments: RECALL 01S24
Tech Comments: PERFORMED RECALL 01S24
1FTNX21F2YEE19062 T/F7 F T/BD T/BD T/E A1 T/DQ T/DS 09-JUN-2000 04-AUG-2000 121680 USA 39 2E06 030008 F81Z 9E527 CRM D13 42 27434
AWS Claim Key: 21812879 Trx Code: S07 Labor Hrs: 20.2
Dlr Cd-Sub Cd: 00994 - * Name: MARTIN FAMILY FORD LINCOLN MERCURY Ph: 828-5844600 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:06-OCT-2003 Doc #:207211A
Cust Comments: CHECK SMOKING AND RUNNING ROUGH
Tech Comments: PERFORMANCE DIAGNOSTICS, CK WITH CYL CANC BOX, REPLACE 4 INJECTOR, ROD TEST.. RETEST RUNS BETTER BUTSTILL MISSING.. REMOVE VALVEW COVER, COMPRESSIT, 4 200 LB.. CALL HOTLINE.. REMOVE ENGINE, REMOVE HEAD, OIL PAN, ROD AND PISTON, ROD BENT. REPLACE ROD AND PISTON.. REASSEMBLE, RECHARGE AC, ROADTEST, RETEST. M TIME FOR USE WHEN NO LAB
1FTNX21F2YEE19062 T/F7 F T/BD T/BD T/E A1 T/DQ T/DS 09-JUN-2000 04-AUG-2000 121680 USA 62 3A11 070100 * 7000 * L72 42 45049
AWS Claim Key: 24937370 Trx Code: SSP Labor Hrs: 3.6
Dlr Cd-Sub Cd: 06717 - * Name: BERGLUND FORD Ph: 540-3897291 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:26-AUG-2005 Doc #:314908A
Cust Comments: CUSTOMER HAD DYE INSTALLED DUE TO LEAK AT TRANSMISSION, REPLACED AT MARTIN FEEGAN FORD 2 11 04
Tech Comments: ADDED DYE FOUND LEAK AT EXTENSION HOUSING. REMOVEDTRANSFERCASE AND REPLACED GASKET TO CORRECT CONCERN.
Interesting my truck had a bent rod about 4 months before I bought it. Think they would replace it with a PMR instead of the forged rods? Thanks
