hotrodstan
When towing in TH Mode, if I get heavy footed in the least from a stop, it slips during the 1-2 shift and it throws the codes(and light). If I baby it, it is OK. Only does while towing. I have smelled the fluid and it smelled burnt. Changed fluid and both filters and the pan and inner filter were clean. It is getting worse as it started when I had the Hypertech set at 2. If I was in factory mode it would not do it. Now it is doing it in factory mode also.
Before, I go to the stealer, I would like to have an idea what it is Converter or 2nd gear clutches or ??? Can anyone help? Thanks
Pardue the Traveler
Can't tell how bad it is till you tear into it.
CRAZY CANUCK
Rebuild time, if its slipping with stock power than your clutches are toast, i would recommend getting it to a good transmission shop, where abouts are you? we could suggest some good transmission builders :happymugs
hotrodstan
I am in East Tennessee, East of Knoxville
