Hey guys, does anyone have the procedure on how to remove the door panel in order to replace the factory speakers, as well as the back seat panels? And can someone confirm the speaker size, I was told they are 6x8, is this true? Will 6x9's fit? Thanks.
The front door is accessed by removing a small panel above the door handle. I might be mistaken but it somewhere in this vicinity. Remove the two screws and lift up the door panel then disconnect the wiring harnesses. Failry simple I suspect the rear door is the same. If I remember correctly they are 6X9 speakers.
