i have an 06 bare bones powerstroke. If you hit the horn, the washer squirters com on, and the right turn signal come on and the headlights come on. Also if you turn on the headlight switch, the right turn indicator is on and washer squirts. I have changed the central fuse block out with a new one and still does it. Any ideas??
this may help or may not help but in my buses twhen you hit the air horn on the turn signal the wiper and washers come on and the door opens and the problem was that they all worked off of the same common ground, so if one of those components is shortiung out then they will backfeed through the ground so maybe thats the cause.
