I HAVE A 03 CHEVY(LB7) W/80K MILES AND EDGE JUCIE W/ATTITUDE, AIR INTAKE,AND 4.5 EXHAUST THAT CAME W/TRUCK. THE PROBLEM STARTED THIS WINTER WHEN IT WAS REALLY COLD AND I HAD TO USE THAT POWER SERVICE ADDITIVE BECAUSE IT WAS 40 BELOW. I REMEMBER FILLING THE TRUCK UP AND RIGHT AFTER THAT IT WASN'T THE SAME. THE FUEL FILTER HAD TO BE REPLACED DUE TO THE TRUCK NOT STARTING SHORTLY THERE AFTER. REPLACED FILTER AND STILL HAVE A HESITATION OR DEAD PEDAL OFF OF IDLE. THE TRUCK STARTS FINE EVERY MORNING AND IDLES FINE. WHEN THE BOOST COMES ON( 2 SECONDS??) THE TRUCK IS FINE PULLS HARD. DOES THE FILTER STILL HAVE TO BE REPLACE CAUSE OF THE POWER SERVICE STILL CLEANING OUT THE FUEL LINE. IS IT TURBO LAG OR BIODIESEL ISSUE OR A FUEL PUMP PROBLEM. NO CODES. QUESTION#2 THE TRUCK IS REALLY ONLY USED IN THE WINTER FOR SNOW PLOWING. THE SUMMER IT WILL SIT IN THE GARAGE, BUT I START AND LET IT RUN EVERY 2 WEEKS. WILL SITTING CAUSE ANY MAJOR ISSUES. THANKS IN ADVANCE FOR A HELP WITH THIS!!! :usflag
