1 - 11 of 11 Posts
I think my GPR is going bad when i turn on key wts light comes on and GPR pulls and puts hard draw on batteries light goes out truck starts fine but GPR stays made for a min or two drawing on bats whole time i only drive 6 mi to work and after a couple days bats go dead when wts light goes out shouldent GPR drop out?????? any help would be great. also new to psd's help with some mods and tech terms would be helpfull too.like what is zoodad , oh yeah trucks a 96 f350 cc 4wd
The WTS light and the GPR aren't directly connected. GPR will stay on for up to 2 minutes depending on conditions. It sounds to me like maybe you have a charging system problem.
Hey thanks KRP, But as soon as GPR drops out it starts charging like mad
FRANKEN STROKE
I have a freind who had that problem. Truned out to be the alternator, but his voltage was bouncing as he drove down the road. Also check your plugs into the head gaskets to make sure they are not burnt!
Hope this helps!
NELSON
Thanks nelson,will check that,my volt meter doesant bounce, but it will go down a bit at idle ,could my short run driving have somthing to do with it???? 6 mi to work 6mi home maybe alt or batts cant handle the big diccharg and short drive time so much??? thanks again
diefree64, I had same exact problem, and I had 1 of the batteries bad, changed both batteries and batt. voltage came up within 30 seconds of starting. hope this helps.
Rodney
FRANKEN STROKE
I checked with another freind of mine and he said to check for a short in the glow plug wiring! DONT DRIVE IT IF IT IS A SHORT IT COULD BURN OUT THE ALT, AND RELAY!! I would look for the short, if u dont find one pull the wiring up off the motor, to make sure it isnt touching metal! Check for burnt relays in the fuse box also!
I really dont think short drive times have anything to do with it, as longe as you let it warm up first! and cool down before turning off!
I hope this helps!
NELSON
Gpr
Like KRP said the wait to start light and the GPR are totally unrelated. The GPR will stay on depending on outside air temp, engine oil temp. The draw you see on your guage is normal to an extent. Without actual readings I can't tell you exactly were to go. It does sound to me like your alternator is functioning properly but you possibly have one or two weak batteries. Load test the batteries it sounds to me like they don't carry a load very well but the recovery sounds fine for the alternator. You can test your GPR by doing a KOEO test. Test for 12 volt operation on the GPR, do this a couple of times because I have seen them go intermittent. If your not seeing 12 volts you need to check your batteries for sure. Also look for discoloration on the glow plug side of the controller, or melting of the rubber boot. For the money just replace if your seeing this happening. Hope this helps, if you have any questions just pm or call me.
Hey thanks to all for the replys,im gonna have my batteries load tested tomarrow,gonna also install a homade air intake and already have a home straight exaust no cat or muffler i shimmed my pump to about 70lbs today was at about 50lbs what will this do for me,I know turning up rail press in nt855 cummins puts more fuel to it but not sure about psd's gonna get a 3" downpipe and some gauges soon too.
thanks to all again
JIM
any help with upgrading power would be great to
oh yea whears the controler located
I think when he said controller he just meant GPR. It is the on top of the engine. Looks just like a starter relay or somehting like that does, can't miss it.
1 - 11 of 11 Posts
