1 - 12 of 12 Posts
F
Is there a way to get my truck to hi-idle any time I want it to? I can set the hi-idle feature to "on" but it doesn't come on unless it is very cold.
'Ol Builder guy
Excellent question. I'd like that, too, but without destroying my wiring harness or voiding my warranty.
There's a way to do it similar to the LB7/LLY, but you have to run 12v+ to the ECM on two pins. I'm not sure if switches are involved, and I don't want to be wrong..
I'm waiting on a guy who's done it to outline it for me.
Please go to our web site "www.gmupfitter.com" to review the Technical Bulletins. You can find them by selecting the following:
Publications
Technical Bulletins
Select bulletin # 71.
Go to Page 4 or 7 which shows the schematic for the PTO system.
You will need to complete the wiring for the LT Green 488 circuit to the PCM C1 Pin 60 and the yellow 2522 circuit to C! Pin 8. You will need to install a latching switch to bridge from the PTO switch connector pin A [Brown 41 circuit] to both pins B and E. This will give you the PTO Enable signal and the Feedback signal to the PCM.
When the truck is parked and idling and you throw your switch it should move up from base idle to about 800 RPM. This is the PTO Standby Speed. You can have your dealer re-program that setting to a higher RPM or you can attempt to get to the SET speed which corresponds to the +12 v signal that would be output to pin G [DK Blue 84 wire] of the PTO switch connector. Since you don't have cruise I am not sure that wire makes it to the PCM pin either. You will have to ring it out and complete it to PCM pin C1 34. When you are in PTO mode [800 RPM] and you send the SET pulse you should go to 1250 RPM. Just remember these signals have to make it to the PCM pins.
Here is the pin information for your LBZ engine controller.
Document ID# 1784530
2007 Chevrolet Silverado Classic - 4WD
6.6L Diesel LBZ LLY [early production w/o particulate filter]
Engine Control Module Connector End Views
Connector 1:
Engine Control Module (ECM) - C1
Connector 2:
Engine Control Module (ECM) - C2
Connector Part Information
OEM: 15438366
Service: 89046933
Description: 96-Way F Sealed (BK)
Terminal Part Information
Terminal/Tray: 1928498135/19
Core/Insulation Crimp: Pins 1-3, 8, 9, 25-27, 31, 49-51, 60, 73-75, 77, 84 - See Terminal Repair Kit
Core/Insulation Crimp: Pins 6, 7, 10-13, 15, 18- 21, 23, 24, 30, 32, 34, 37-42, 44, 47, 48, 53, 55-58, 61-63, 65-68, 71, 72, 76, 78, 79, 82, 85, 86, 88, 92, 96 - P/P
Release Tool/Test Probe: J-38125-213/J-35616-64B (L-BU)
Pin
Wire Color
Circuit No.
Function
1
OG
5421
Injector Positive Voltage Control Group 1
2
D-BU/WH
878
Fuel Injector 8 Control
3
RD/BK
877
Fuel Injector 7 Control
4-5
Not Used
6
OG/BK
469
Low Reference
7
PU
806
Crank Voltage
8
YE
2522
PTO Engage Signal
9
BN
1174
Oil Level Switch Signal
10
GY/BK
87
Cruise Control Resume/Accel Switch Signal
11
GY/BK
6272
Low Reference
12
GY
2704
5-Volt Reference
13
TN
5928
5-Volt Reference
14
Not Used
15
GY
2705
5-Volt Reference
16-17
Not Used
18
YE
492
MAF Sensor Signal
19
L-GN
432
Turbocharger Boost Sensor Signal
20
YE
5947
Turbocharger Vane Position Sensor Signal
21
L-BU
1162
APP Sensor 2 Signal
22
Not Used
23
BK
2755
Low Reference
24
PU/WH
2530
Fuel Pressure Regulator Solenoid Supply Voltage
25
PK
5425
Injector Positive Voltage Control Group 4
26
YE/BK
846
Fuel Injector 6 Control
27
PK/BK
1746
Fuel Injector 3 Control
28-29
Not Used
30
OG/BK
2919
Low Reference
31
L-BU
494
Engine Shutoff Signal (PTO w/A/T)
32
GY
48
CPP Switch Signal
33
Not Used
34
D-BU
84
Cruise Control Set/Coast Switch Signal
35-36
Not Used
37
GY
2703
5-Volt Reference
38
TN
1274
5-Volt Reference
39
TN
2917
5-Volt Reference
40
PU/WH
6270
5-Volt Reference
41
RD
6259
5-Volt Reference
42
TN
472
IAT Sensor Signal
43
Not Used
44
TN/WH
332
Oil Pressure Sensor Signal
45-46
Not Used
47
GY
720
Low Reference
48
D-BU
5930
Turbocharger Vane Position Control Solenoid Valve High Control
49
PU
5423
Injector Positive Voltage Control Group 3
50
BK/WH
845
Fuel Injector 5 Control
51
L-BU/BK
844
Fuel Injector 4 Control
52
Not Used
53
YE/BK
6120
Low Reference
54
Not Used
55
GY/BK
2931
Low Reference
56
D-BU/WH
6265
CMP Sensor Signal
57
GY/BK
1694
4WD Low Signal
58
L-GN
1478
Coolant Level Switch Signal
59
Not Used
60
L-GN
488
PTO On Switch Signal
61
GY
397
Cruise Control ON Switch Signal
62
BK
552
Low Reference
63
OG/BK
5929
Low Reference
64
Not Used
65
L-BU
6118
IAT Sensor 2 Signal
66
Not Used
67
BN/WH
5763
EGR Valve Position Signal
68
YE
410
ECT Sensor Signal
69-70
Not Used
71
YE/BK
625
Starter Enable Relay Control
72
YE
2834
Fuel Pressure Regulator Solenoid Control
73
YE
5422
Injector Positive Voltage Control Group 2
74
BK
1744
Fuel Injector 1 Control
75
L-GN/BK
1745
Fuel Injector 2 Control
76
PK
1039
Ignition 1 Voltage
77
OG
440
Battery Positive Voltage
78
PU
1272
Low Reference
79
WH/BK
6271
CKP Sensor Signal
80-81
Not Used
82
BK/WH
1695
Axle Switch Signal
83
Not Used
84
GY
1524
Backup Lamp Supply Voltage
85
YE/BK
508
Water In Fuel Indicator Control
86
BK
2754
Low Reference
87
Not Used
88
BN
6266
Low Reference
89-91
Not Used
92
YE
2918
FRP Sensor Signal
93-95
Not Used
96
WH
5931
Turbocharger Vane Position Control Solenoid Valve Low Control
F
Looks like it is alot like the 6.0's. I will get some pics next week when I try this, hopefully at the same time I wire up my aux. fuel tank.
F
I thought they were not going to do the DSP5 for the LBZ?
1 - 12 of 12 Posts
