1 - 20 of 30 Posts
I was woundering why the standard output engines are easier to get more power out of them then the high output motors:happymugs
There seems to be something in the electronics of the pump and the flow rate I believe. If your looking for better power and need a new pump just put in a so and go
2nd Gen Guru
Sad but true the SO VP44 has more volume of fuel than a HO VP44...
Then there is a electronics difference with the 2 pumps...
If you ask around you'll find all HotRod VP44's are built from SO Pumps...
Ghost
Electronics don't respond as well to mods.
VP44 plungers are smaller in the HO/ETH.
The standard outputs/ETC also have the lowest compression of all the Cummins 5.9's. Making boosting easier.
So, if the HO VP's flow less fuel, how do they make bigger HP & TQ numbers in stock form?
more compression and I think larger injectors.
********* and Mafia #90
higher CP, less boost needed to achive it.
The higher the compression the greater the low end torque, but it causes trouble breathing the higher the RPM go.
Of Course
Because I am curious. I don't remember claiming I knew everything about anything. I do believe you have a problem with people who are knowledgeable and question what you say.
Ghost
So you are claiming that you didn't know what allowed for the higher compression between the ETH and ETC. But you do know the VP44 doesn't back off timing under boost. Interesting knowledge there.
Of Course
The piston bowl is 3mm smaller on the HO vs SO, hence the difference in compression ratio. I know a thing or two, but my knowledge probably doesn't interest you. The VP44 advances timing with load and RPM just in case you were still unsure.
Ghost
The piston bowl is 3mm smaller on the HO vs SO, hence the difference in compression ratio. I know a thing or two, but my probably doesn't interest you. The VP44 advances timing with load and RPM just in case you were still unsure.
So first you didn't know, then you change your mind and have the exact measurement of the piston bowls. You're right, your "probably" doesn't interest me.
Easy guys, constructive criticism in the posts only please. You guys know way more then me abought the cummins thats for sure. :thumbsup
Of Course
Why did you ask? You claim to know everything about these trucks, but then ask why the ETH had higher compression.
Because I was interested if anyone else knew the answer. And since you did not, but chose to derail this thread, I would like to congratulate you.
I hope the next post will help the Original poster.:nunu:
:happymugs
1 - 20 of 30 Posts
