1 - 10 of 10 Posts
Okay so I was in bumper to bumper traffic today in the blistering head and my trans got real hot on the way home (about 30-40 minute drive). It stayed above 185 for the majority of the drive, and the highest I saw was 196. My question is not what caused it cuz i know it was the bumper to bumper driving and high heat/humitidy, but is there anything I need to do like change out the fluid since it got that hot?
Thanks
You should be fine at 195, 220-230 is where you have to get fluid checked and/or changed.
Reactions: O2ShootTheJ
Okay thanks for the quick reply
Yea i've been seeing between 185 and 201 lately with this high heat. Trans still shifts fine. Got 25K on the truck running 275 the majority of it.
Not a problem.
I like Pretty Girls!
I have seen mine as high as the yellow on the dash gauge and I think that was close to230..... It was the first time I heard my fan come on.
I was towing a light load (6000 pnds) off road through a mountain road in about 35C so my thoughts are if its only in the warning/yellow part on the gauge anything less should be fine
what is the real max temp?
A stock truck has the fan kick on at about 230 and the tranny temp guage is right in the middle?
FukeneH
? what are you asking,when should you change the oil? when you will do damage? when will it melt? 230+ you WILL start burning additives out.friction not your friend
1 - 10 of 10 Posts
