last night got in truck to head home turned ket to start and had 0 psi of pressure. so towed truck home. turned truck back on to see if pump works and 15psi and hear pump running. When pump was not working I did crawl under truck and hit it with a test light and had power down to the pump and hooked up a 12v electric fan to see if I had wiring issues and the fan worked. so the holley must be getting ready to give up. I have the big line kit what pump will last longer than a year and still be able to use my big line kit fittings. I ordered the kit for the holley so I don't have stock hardware to bolt in an airtex
2nd Gen Guru
