Singles Club Member #34
does the holley black have to use a pressure regulator or can i just run the pump i need the truck for work tomarrow so i really need to know if it ok or if its gona hurt it???
Do you have a gauge in there to see what its putting out? Usually they are fine, but when installed with the stock lift pump still running it may get a little high. The only real damage I could see resulting would be forcing the metering diaphragm to hyper extend. But unless your vp has been subjected to fuel press below 5psi, that shouldn't be an issue. A regulator wouldn't be a bad idea if you have one kickin around, but it should work fine without one. Main thing is to get a gauge on there and see what its actually doing, if you don't already have one.
ya thanks sean it will go on tonight with the big line kit and the stock lp is getting 86'd and as for the gauges as soon as i get the money there going in.
holley blue
I was planning on running a holley blue on my 99. I didnt know if i should disconnect the factory lift pump in the tank or if it would be fine if i left it running. If so, what psi should it run at. Thanks
Jimmy
im getting rid of my factory pump and just running the holley black ive heard you can run both together though u need a pressure regulator which should come with the blue pump.
from what I was told keep it under 20. I would say regulate it to where you don't get a huge drop from idle to wot. but it's all in what works for you.
