1 - 12 of 12 Posts
I am just wondering what is the stock HP of the cummins and torque, I am guessing somebody can answer this.
B
I am ssuming you have a 24v since you posted in this forum? Do you have a standard output or high output? I think the standard was around 235 and the HO was around 250. I don't think those are correct, but in the ballpark. Someone will chime in here with the exact numbers.
Also please take a few minutes and fill out your signature, that way in the future we can better help you by knowing what you have.
Yeah the rating really varies from year to year and depending on whether you have a stick or an auto. You can look on your engine data plate on the drivers side of the timing case and that will tell you hp and the Rpm that rating is obtained at.
My 2000 2500 auto is rated at 215hp @ 2700 rpm which roughly calculates to 420ft.lbs of torque.
98-00 autos should be close to that number, manuals should be roughly 225hp.
01-02 auto (S.O.) is roughly 225hp
01-02 5spd (S.O.) is roughly 235hp
01-02 6spd (H.O.) is roughly 245hp
1998-2000 automatic 215hp - 420lb/ft
2001-2002 automatic 235hp - 460lb/ft
1998-2002 5spd 235hp - 460lb/ft
1999-2000 6spd 235hp - 460lb/ft
2001-2002 6spd 245hp - 505lb/ft
The 01-02 autos I wasn't sure about, thanks for clearing that up.
On The 01-02 Whats The Difference Between The Ho And The Normal Cummins?
I think a slightly different turbo but im not familiar with the H.O.
The HO pumps have different electronics(timing) and smaller plungers than the SO pumps 7mm vs 7.5mm. The HO pumps also run higher fuel pressure, but they use smaller injectors. You could get a SO truck with a six speed from 1999 to 2000. The NV4500 and SO NV5600's have a 1 1/4" input shaft, the later NV5600's have a 1 3/8" input shaft.
to add to what smokem said, the S.O. motor runs 16.4:1 compression ratio and the H.O. runs 17.0:1.
where is the difference? piston, head gsk, block, head?
The pistons are different between the HO and SO motors. The turbo on the HO is wastegated to 26psi vs the SO at 21psi. The HO motors have press in valve seats and the SO motors do not. The HO has higher fuel pressure than the SO, but the injectors are smaller 600cc's at 100 bar for 30seconds vs 640cc's at 100 bar for 30seconds. And the HO motors have a larger flywheel than the SO motors, 330mm vs 310mm. The difference in the piston bowls allows for the HO injector to spray out of the bowl much easier with less fueling modules than the SO piston bowl. Sorry for the delayed response, I've been crazy busy, does this answer your question?
1 - 12 of 12 Posts
