1 - 14 of 14 Posts
OK dont bash but does anyone know how to unlock an edge juice/A.
Yep. Get the serial # off your box through the monitor then give edge a call give them the info. They will fax you a waiver which you have to sign and fax back to them. Pay them a hundred bucks and they will give you a 4 digit code. Enter it into the box and let'er rip.
Can it be done without edge and without paying the 100.00
each code is specific to the serial number of the chip and it consists of numbers and letters so i guess you could start guessin or pay the money
Ya that would be alot of guessing. I guess I will give them a call and part with the cash.
no hp gains it jus changes the way that it fuels on the top end
your missing a hole bunch if you dont got the unlock code.
i was thinking about getting injecters but changed my mind after unlocking it. the power stays alot longer.
Cause I was thinking of putting a set of injectors in as well. Stage 3 is what I had in mind. If I unlock the hot code, is that worth the 100 bucks instead of injectors? I want her to pour some smoke :smoke
I have the unlock code now. It alot different it pulls so much harder. I also have stage 3 injectors and together it will put out smoke so bad that you can not see anything behind you:woot: :woot: . If you dont get the injectors to me it's like a fire hose with a garden hose nozzle on it. You cant get as much fuel through the stockers.
I got my hot unlock then i got a smarty. After installing the smarty the hot unlock was a waste of $$$, smokes great for tailgaters but runs like crap for performance. Save your money from the unlock and put it toward something else like injectors or a smarty, not the change in the fueling curve.
Smarty 600$
Unlock code 100$
what do you mean it runs bad? do it surged or what? just curious
1 - 14 of 14 Posts
