Do you want to know how to remove it to work on it, or remove it to delete it?
To take it out of the truck, you need to remove the vibra lock fittin from the driver's side of the fuel bowl, there are two fittings to remove from the passenger side that feeds the heads. There are two bolts that go through the front of the HPOP resevoir to remove and then the filter bowl will be loose. You will need to disconnect the electric connections and the drain line before you can totally pull it out. .. oh, and don't forget to drain the bowl first. . .that will save some of the mess.
Thanks for the reply trick76cj5! I finally noticed one of my fuel lines was keeping me from removing it. Your input is appreiciated.
