Well Im not planning on going crazy with my brothers truck. He wants a PPE hot and thats it. He isnt into racing or anything of that nature. He doesnt tow more then 8K lbs and only a few times a year. Just wondering if its really neccasary to get a aftermarket exhaust with what he is trying to do.
TDG Mafia # 81
It would be beneficial to get a good exhaust. Just to remove restriction, helps the flow properties with the new programmer.
Tony
I would add an exhaust if I'm adding a programmer. Helps keep the EGT's down, especially when towing. An EGT gauge is a good idea, too.
BTW, dont let him go over +100rwhp on a stock tranny.
If cost is a factor but noise isn't cut out the muffler and replace it with a piece of pipe. If you don't get in the throttle too much it isn't that loud, but if you hammer on it...
I have pics if you want.
Aftermarket exhaust beneficial?
Using the stock exhaust with the muffler cut out is an improvement over stock, but a very small one...Exhaust costs a bit, but it will bring EGT down (I have gone both routes). If you are planning to use a chip, its really better to go with a good 4" exhaust.
If you wanna be cheapo, a straight through muffler or straight pipe will be under $100 by replacing the stock muffler only.
Another cheap route is a 5" single stack striaght pipe from the turbo back, this is what I did and flows nice, but its a little loud.
A cheap 4" exhaust is less than $300. Soo let him make the call.
The PPE does get hot but not long enough to do serious damage.
