My truck has 179000 miles on it, how much is too much blow-by? It has like a little stream of white/blue smoke coming from the oil fill when I remove the cap. Its similar to a lightly smoldering cigarette. Is this too much or about normal?
MAFIA MEMBER 106
the rings dont seat @idle so i would say norm
So if you idle up your truck will you notice the blow by disapate? Also couldn't the blow by be the oil releasing gases from being heated also just like when you heat up cooking oil?
a little bit is normal. If you arn't useing much oil I wouldn't worry about it.
Discussion Starter · #5 ·
I am wanting to make 425 rwhp, would 160 cc single shot injectors, Terminator or similar HPOP, and Dominator 66 Turbo from Beans put me in that area? Would I be able to do the injectors and HPOP, before the turbo?
