yes i no i have a dodge dokota i had 2200 pounds on it
i have a 671t detroit diesel it was out of a fire truck that has 64000 miles on it with a 5spd none overdrive, i want to try to use the c70 frame or some thing like that for better steering and brakes, i have a r190 ih cab that was a fire truck it has a long hood the hood is over 50 inches and the fire wall is set back from stock should fit, it will be only 2 wheel drive go to truck shows
must people ask why a detroit diesel i grow up with them and like them i got the motor and trany for 900.00
i also found a set of jake brakes for it i just like the sound of them drove one for quit awile
Nuthin wrong with a Detroit two cycle. I kinda like them myself with a set of ear plugs........
Both IH, and GM used a straight rail frame very near 34" outside diameter through the years. If you are planning to build an IH on a GM frame you will need to remove the cab and front sheet metal mounts from the original frame to install onto the donor, or cut and splice the frames together. You could also remove what you need from the GM and install onto the IH frame. I've not worked on a 4X4 setup on medium duty trucks much and assume this is a Napco, (sp) conversion? If you existing frame is in decent shape, it would be easier to locate a later model truck with the same spring perch spacing and just swap the steer axle.
I wouldn't use that trans however. An RT-910 Fuller is a 25% split evenly through all the gears and is both easy to shift, and very forgiving. It is an older transmission and therefore not expensive. The only drawback was a relatively fast, (for me) back up speed with a short trailer. With a straight truck, no problem.
