1 - 12 of 12 Posts
...do I remove the square head nuts on the fuel ports?:shrug:
Tim
An adjustable wrench, a box end wrench?
I guess I don't understand the question since I have an OBS.
yeah, i guess I could try a crescent wrench. I was hoping for a special tool that fit more securely around the nut. I'm just afraid of rounding the edges and never getting the things out.
Is it possitioned where you can tap on the head to jar the threads a little? That might help loosen it before the "rounding" begins.
ah, looks like ITP got there link fixed for the reg-kit install. I need a 9/32 4-point socket.....which I can't find anyplace.
Why the heck do these auto makers use such funky factory fittings?
Your local Mac or Snap-On dealer will probably have the socket. An end wrench will work if you are careful.
Still no luck finding a 9/32" 4point socket. This is the only part holding me from finishing my reg return install. I can't get these stupid things out. I've tried penetrating lubricant and various wrenches. Vise grips just won't hold good. Now what??
Tim
Tim
I have never heard of a 4 point socket... Get an 8 or 12 point, either of those should work...
That is.... If you have not already rounded it off by using vise grips.
TDG Mafia Member # 37
Wher did you get the kit? Mine came with the 9/32" 4 point socket in the kit. Gene :mafia
Discussion Starter #12
Putting the fuel system together myself. All new lines from the tank to the return. Plus I ripped out the fuel bowl and installing a couple prepump spin on fuel filters. Pretty much the only thing I'm not changing is the pump....for now:sly:
1 - 12 of 12 Posts
