I need to know what resistor to use to trick the hpop into thinking it is not building enough pressure and bumping it way up to the point of lobe idling. for sled pulling purposes only.
You can pop any number of resistors in there, I won't get into the values, as I am sure that there are plenty of resistor trick guys on the boards, BUT...
This device can be tuned on the fly to jack your idle pressure way up (and down)....Probably more ideal and tuneable for your sled pulling. I can get my test rig whompin(is that even a word?) by cranking my idle adjust way up.
Also the boost control in this will add some off the line grunt too.
