The womans truck broke the right side fuel line coming out of the fuel bowl and going to the right head.
Here is the pic of the fuel line.
There is a clamp that holds the fuel line in place. Over the years and 140,000+ miles the clamp wore a pin hole in the fuel line.
Here you can see the pin hole in the line.
I took some rubber hose and split it down the middle. I placed the hose over the line. I beat the clamp flat and then formed it around the new line and hose.
This is a dealer part only!! You will drop about $60.00 on it. Here is the part number from Ford.
Hope this might help someone :happymugs
Reactions: John_G
