I got the lower half removed but am having trouble with the upper half. I cannot seem to figure out how to remove the large plastic piece that surrounds the ignition assembly. Anybody know how to do this?
take the three srews out underneath put key in ignition turn to run stick a small phillips screwdriver up the empty hole underneath to release ignition switch pull it out and the plastic will come off oh sorry you have to take the tilt lever off to it just unscrews
you might need to get a presision screwdriver set kinda a tight fit
Discussion Starter · #4 ·
I got it. Just snaps off the ignition assembly.
