hey just wondering what you guys are doing to run 60+psi of boost when it comes to the map sensor... is there a aftermarket map sensor u buy or do you use the little fooler bleed off valve oh we have a 06 dodge 2500 diesel
Hey, I don't see anything wrong with shameless self promotion. Yes, most boxes plug into the map sensor and will act as a boost fooler. You'll just need to make sure you don't pop a head gasket, and have enough fuel and the right turbo to make 60psi.
