1 - 13 of 13 Posts
Just learnin and waitin..
I'm new to the site and how to use it and i've been trying to find out if the pump off of a 99-03 7.3 would mate with the one on my 96 for a twin hpop setup. I thought they were the same but i wanted some advice before i bought it and tried to find a kit
they are different as in the guts are different and the newer pumps will pump a little more oil but they can be mixed and matched with out any problem as long as your not running a older pump in a superduity bvy its self because it may not keep up with the split shot injectors.
I think there are several people running around with 2 different pumps in there big oil setup.
thanks, Do you know anywhere i can by just the kit to put them together? I looked at terminator but i could only find complete setups
A 15º and a 17º will work just fine.
Contact Terminator and ask if you can send both pumps for the oil system. Joey will take care of you.
You can't buy a "kit" from turdinator because he has to assemble them. There has been a bunch of issues with them leaking in the past when others have assembled them due to too much tolerance in the machining of the 0-ring recesses and the bolts that hold it together. Supposedly it's been fixed but apparently they aren't good enough for anyone to assemble except in house. You can buy a DIY Stealth kit for about half the cost of the turdinator and you can assemble it yourself. There is a site sponsor on here that has said in the past they are able to put everything together for you that you'll need for just over $1000. The other option is the Swamp's Gen III pump. It flows more oil than any of the dual stock pump set ups and is way simpler to install. It runs about $1500 so it fall right in between the expensive assembled dual pump set up and the inexpensive DIY dual pump set up.
You lie Geoff.
I dont know how someone can have so little of a life and be so miserable of a little sissy ***** that they have to lie over and over and over about something in which they have no interest at all.
What you said about Terminator was a lie and hopefully no one listens to you.
You need to grow up and start acting like someone instead of running your mouth with nothing to back it up.
Mispronounce my name, or Terminator to my face for that matter and you'll find out what I'm talking about first hand.
I say get a life and STFU
Nothing like the pot calling the kettle black there greg.
No lies either. It's a FACT they had oil leaking issues. The cause was there was nothing to align them and the o-rings would sit half way in the middle of the passage causing leaks. That is a FACT that has been confirmed by multiple people that I've talked to who did not know each other.
Reportedly they started putting some dowls in them to so they will properly align themselves. But if it's such a fool proof design now then why do they have to all be shipped assembled? And why is it so critical that the ONLY place that have them apart is in house or all warranty is VOID?
Yep that's the place I was thinking of.
That hasn't been an issue for a long long time Geoffrey. You need to get with the times :pointlaugh:
I love how you use words like "reportedly".
For the record, I can point you to several people who have had oil leaking and a host of other issues with the Stealth. They're the ones who don't even have bosses cast for the O rings in the aluminum block! :eek:
Regardless though, I'm not here to bash another company like you are squirrel.
The facts are you lie, you have no idea what you're talking about, and you haven't had credibility with anyone who knows anything about you in a long time. Every time you open your mouth you dig the hole deeper. I pity the soul that follows YOUR advice on what parts they should use to have a nice setup.
Oh, and the pumps are assembled in house because there are things that need to be done to setup the pumps properly, and Terminator can feel confident offering a lifetime warranty if they do it.
Take a look at this Geoffrey.
The Terminator HPOS Carries a LIFETIME WARRANTY!
This warranty covers the parts and workmanship of the pre-assembled system from TE
Warranty does not cover the pumps themselves as they are a factory part and not manufactured by TE
Any tampering with the assembled unit will VOID this warranty completely
What does this mean?
This means Terminator offers you a lifetime warranty because we are confident that our system is the best on the market and we want to prove it.
Terminator Engineering can offer you a lifetime warranty because we use the best materials on the market and our machine and assembly work is held to exacting quality standards. If it's not perfect, it doesn't leave the shop.
You can rest assured that you have the best, most reliable system possible, and that if anything does happen Terminator will be there to take care of it.
That's performance with peace of mind!
Fact is you get what you pay for. The company you mentioned is very unprofessional in that they openly have to bash their competition on their site. Why are they so defensive if their systems are so good.
On the other hand Terminator offers quality products, constant innovation, and are backed by the best warranty in the business.
If something happens, it will be taken care of, simple as that.
I'm done here, you dont deserve any more of my time.
Lifetime on the whole pump vs 1 year warranty on Manufactures parts
Gregory sorry to burst your bubble but I don't lie. You show me where I've lied? Pretty much all the oil systems have had failures. That can't be denied. The only one I haven't really heard much failures from is the BTS kit. Does the stock oil pump use any kind of down pins? NO! Why not? Because they use a gasket that is designed not to have any issues if they aren't 100% perfectly lined up. And the stealth uses the better quality OEM gasket eliminating that issue.
I say reportedly because joey claims to have put dowl pins in. But then he claims a lot that's not ture so who knows. But if the kit was SOOOOO well put together why would he make it so that he is the only one that can put them together? If the kit really was that great anyone could do it.
I'm glad his aluminum block and shaft copuler has a lifetime warranty. What's going to go wrong with it? Not much. It's a machined block of aluminum and a coupler. No moving parts are warrantied. Besides if a part is going to break it's going to do it withing the first year unless it's a wear related failure. So the 2 year complete warranty on the entire system including the pumps from the competition IS a better warranty.
I haven't been digging through every venders web site so do you mind showing us where the other vender is bashing their competition?
And by the way calm down gregory and don't take everything so personal. You're likely to have your blood pressure spike and have some real health problems if you keep getting to riled up.
Perhaps you overlooked this:
1 - 13 of 13 Posts
