I have a 2003 f250 with 7.3 only has a dp tuner on it. My problem is the HPOP is leaking its just the o rings seals but if im going to get in there to fix them should I just put in a t500 ? how do i tell if i need to replace the HPOP ?
Thanks
Connor
IF YOU HAVE ACCESS TO A SCAN GUAGE OR OTHER MEANS OF CHECKING THE HIGH PRESSURE OIL, THAT WILL TELL YOU IF IT NEEDS REPLACING. iF THE PRESSURES RUN UP OVER 3000, PROBABLY ONLY NEEDS O RINGS.:happydance:rock---bOB
I'll try to get a hold of a scan gauge
I bought mine at autoanything.com.
They have a deal right now 10% off and free shipping. Use promo code EJA1331P
You can repair it or just upgrade to the T500. Regardless of if it is holding high pressure or not, you do not want an oily mess in the engine valley.
We carry the T500 if you are interested in upgrading. Shoot me an e-mail or PM if you have any questions.
