i have this surging going on at cruising speed on the HWY. Its on and off, not a constant surge. If i give it some load for a sec it goes away, but as i continue cruising it comes back.
Any idea of what going on?
I know the smartys used to do that, also when my buddy had big inj his did that too......he had to hold his foot on the pedal just a little, but only on cruise control
Discussion Starter · #3 ·
yeah i just took the smarty out and went for a spin, didnt stutter like it did earlier, but then again, its on and off so maybe it just wasnt acting up this time. i just put the smarty back in and im going to go drive it again to see whats up.
It's the fuel delivery my 12v did that big DV's It's to much for the cruise to control!.... little pedal = alot of power!!
Discussion Starter · #5 ·
still no stutter with the smarty either....i dont know.. when i said cruising, i meant holding the throttle position and speed, not the actual cruise control..sorry
i have seen that in 12 valves autos when they get the govern spring to tight. you are either on the gas or off. cursing = bucking/ surging. there is no in between. im sure that you have the wild torque management program. i would try a mild torque management program an see if that helps. i know you dont want to go backwards in power but it might help until you further diagnose the problem.
