1 - 20 of 29 Posts
No I am not trying to get away from a fat girl. (All though they do scare me). I am trying like hell to get some good recovery equipment. I have the tow rigs now I need trailers. Once I have them, I will need some big winches to mount on them. I know very little about the big boys. I want to mount one on a 53 foot flat bed that will haul heavy trucks and equipment. I need another one to mount on a 40 foot gooseneck that will haul lighter trucks and equipment. The forty footer will be towed by my F350 and the fifty three footer by a M915. So has you can see, I need some big winches capable of dragging non running loads up on the trailer decks. Should I go hydraulic or electric? Should they have their own power source or draw from the tow vehicles’ power? What are the maintenance issues I should consider? If one breaks in the middle of a recovery what options do I have to get it running and complete the recovery? What cable and material size should I be using for these types of jobs? Where should I look at as far as buying these winches? And most importantly I need a price range. I have more questions to follow, but these are a good enough start for now.
Oh, these are my tow vehicles.
Many of those Military trucks have hydraulic winches. It really will depend if you want PTO, Electric over Hydraulic, or Electric as their are many choices available. Chris
Most trailers I see here have a wet kit on the truck and connect to the winch on the trailer with hose, just like if it were a dump. If you want electric you will need some heavy cables to get the power back there.
I am thinking electric on the smaller trailer. So you aresaying the power unit is installed on the truck and the drum just connects via hydro cable. Correct? If that is the case I think it would work.
Administrator
I used one that had a wet kit on the truck and the hydro winch was mounted on the truck. Had a couple pulleys if the trailer was at an angle to the truck. Worked better for the situation, where you may have a different trailer. Just a thought for you.
I thought about that. But by the time I can afford more trailers, I hope ot have different trucks any way.
If you mount it to the front of the trailer make sure it is a stout anchor point. You might try looking at some roll off bins and how their trailers are set up. Most have the winch on the truck with a PTO, but I have seen a couple with the winch on the trailer. Warn makes a 16,000# winch that is electric. That might be a good starting point for the smaller trailer. Rig up a couple of anchor points and use some snatch blocks and you may not need as big a winch as you are thinking about. Keep us posted as to how this turns out. Tulsa Winches are pretty good. I don't know if they make a hydraulic unit but it might be worth checking into.:thumbsup:usflag
I refuse to grow up
DP winches ("Tulsa") are good, and have an air pressure actuated freespool, worth it's weight in gold after you've pulled the cable out under power a few times in the rain.
the hyd ones, used on 1000's of wreckers, hold up great, and hold more cable than you'd ever need, and have tensioners built onto them, keeps the cable from ratsnesting on the drum. some have 2 speeds, but you wouldn't need it for a trailer.
for your big trailer, (having run landoll trailers a bit) I'd look for a 20k or 25k winch, more than enough to drag, and will hold more than enough cable to use a snatch block for loading and unloading, also, it's big enough to snatch off the tail of the trailer to slid it (EMPTY!!) or pull yourself backwards when (not if) you get stuck. anything bigger would be a waste of $$, smaller be alot of extra work with snatch blocks.
2 points (learned the hard way) after re-engaging the freespool, rock the drum in and out 3/4 turn, this reseats the teeth in the freespool assy, and put a pressure gauge on it, avoid pulling at over 2000PSI, if that high, add a snatch block. the brass bushings in the drum and planetary don't like pulling harder than that
you could call purpose wrecker, (i think) columbus or columbia, mo. just west of st louis. they buy and overhaul used wreckers, and mount new beds on older trucks. might have an older winch for sale.
one option for power, mount a pony motor (10 hp or so) and the pump/tank on the nose of the trailer or on the tractor, then it's self contained and easy to move to another power unit
ADMIN/MAFIA
Thoughts and opinions on this winch for the smaller trailer
http://www.warn.com/truck/winches/src/165ti_winch.shtml
Every Warn product that I have used has been top notch. if it fits the working load you plan to throw at it Id say go for it. by buddy has a ramsey 10k on his load trail/load max goose and it works well for pulling 2 cylinder deeres up on it. so I would say the warn would be a better choice.
Discussion Starter #16
I figured that 16.5 and a snatch blcok will drag a dead truck up on the trailer.
What about parts? If I need parts Is Warn good about having them?
Having never broken one in the past I don't know. Based on their reputation and time in the business I would bet parts are readily avaliable. Why don't you send them an e-mail and ask about parts. Explain that this is a business venture so down time is no money time.:thumbsup:usflag
ADMIN/MAFIA
everytime I emailed Warn I got a reply the next buss. day and even a phone call once..I would say they will more than be willing to work with you if you have a problem. I wounldnt expect a problem with any of their stuff.
1 - 20 of 29 Posts
