Standard Claims List For Model Year 2000
1FTNW21F3YEE01270 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 30-MAY-2000 15-JUN-2000 123002 USA 0 2E03 031401 XC3Z 12B599 AA D50 42 10
AWS Claim Key: 1678418 Trx Code: S07 Labor Hrs: 4.2
Dlr Cd-Sub Cd: 05950 - * Name: OAKLEY-KEESEE FORD INC Ph: 901-3825555 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:12-JUN-2000 Doc #:09708251
Cust Comments: CUSTOMER STATES ENGINE HAS MISS, WHILE DRIVING,
Tech Comments: INJ DRIVE MODULE INOP ENGINE PERFORMANCE DIAGNOSTICS 7.3L DI TURBO ENGINE DIAGNOSIS
1FTNW21F3YEE01270 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 30-MAY-2000 15-JUN-2000 123002 USA 4 7T03 060901 F81Z 2C204 BA H19 42 2959
AWS Claim Key: 3602959 Trx Code: 1 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 05950 - * Name: OAKLEY-KEESEE FORD INC Ph: 901-3825555 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:06-OCT-2000 Doc #:01984651
Cust Comments: ABS LIGHT ON AT TIMES
Tech Comments: RF SPEED SENSOR INOP ANTI LOCK BRAKE SYSTEM DIAGNOSIS
1FTNW21F3YEE01270 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 30-MAY-2000 15-JUN-2000 123002 USA 4 5K04 040402 * ALBAL * N25 D9 2959
AWS Claim Key: 3602960 Trx Code: 1 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 05950 - * Name: OAKLEY-KEESEE FORD INC Ph: 901-3825555 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:06-OCT-2000 Doc #:01984652
Cust Comments: VIBRATION AT 60 65MPH
Tech Comments: TIRES OUT OF BALANCE WHEEL AND TIRE ASSEMBLY BALANCE
1FTNW21F3YEE01270 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 30-MAY-2000 15-JUN-2000 123002 USA 14 1A03 030101 * 6026 * L65 D8 10286
AWS Claim Key: 9559618 Trx Code: E84 Labor Hrs: 8.1
Dlr Cd-Sub Cd: 04357 - * Name: DOBBS FORD LINCOLN MERCURY AT WOLFCHASE Ph: 901-3825555 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:12-JUL-2001 Doc #:04890251
Cust Comments: CHECK ENGINE LEAKING OIL
Tech Comments: REPLACE RIGHT REAR HEAD PLUG
1FTNW21F3YEE01270 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 30-MAY-2000 15-JUN-2000 123002 USA 16 5V01 050301 F81Z 1104 BG H19 42 12367
AWS Claim Key: 11869371 Trx Code: E84 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 04357 - * Name: DOBBS FORD LINCOLN MERCURY AT WOLFCHASE Ph: 901-3825555 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:14-SEP-2001 Doc #:05626951
Tech Comments: REPLACE FRONT HUB BAD EXCITR RINGPIN POINT TEST DIAGNOSIS
1FTNW21F3YEE01270 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 30-MAY-2000 15-JUN-2000 123002 USA 16 * * * * * * * 12367
AWS Claim Key: 11869372 Trx Code: 01S24 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 04357 - * Name: DOBBS FORD LINCOLN MERCURY AT WOLFCHASE Ph: 901-3825555 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:14-SEP-2001 Doc #:05626952
Cust Comments: RECALL 01S24 WIPER COVER
Tech Comments: PERFORM RECALL ##X## INSTALL WIPER MOTOR COVER
1FTNW21F3YEE01270 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 30-MAY-2000 15-JUN-2000 123002 USA 21 7T03 050301 F81Z 2C204 BA H19 42 20134
AWS Claim Key: 14761111 Trx Code: E83 Labor Hrs: 2.9
Dlr Cd-Sub Cd: 04357 - * Name: DOBBS FORD LINCOLN MERCURY AT WOLFCHASE Ph: 901-3825555 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:21-FEB-2002 Doc #:07164052
Cust Comments: ABS LIGHT FLASHES ON AND OF 2 TIME REPAIR
Tech Comments: REPLACE SENSOR AND MODULE
1FTNW21F3YEE01270 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 30-MAY-2000 15-JUN-2000 123002 USA 21 2G05 031405 * RECAL * D50 07 20134
AWS Claim Key: 14735419 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04357 - * Name: DOBBS FORD LINCOLN MERCURY AT WOLFCHASE Ph: 901-3825555 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:21-FEB-2002 Doc #:07164053
Cust Comments: CUSTOMER SAYS LACKS THE POWER THAT IT HAD WHEN FIRST PURCHASED ONLY GETS 2600RPM TOPS OUT AT 90 USE TO GET UP TO 3200RPM
Tech Comments: REPROGRAM PCM
1FTNW21F3YEE01270 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 30-MAY-2000 15-JUN-2000 123002 USA 58 2G02 0300XX F7TZ 12K073 A D21 42 51064
AWS Claim Key: 24013600 Trx Code: E72 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04357 - * Name: DOBBS FORD LINCOLN MERCURY AT WOLFCHASE Ph: 901-3825555 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:03-MAR-2005 Doc #:06954702
Cust Comments: C S STOPPED GOING DOWN ROAD AND WOULDNT CRANK
Tech Comments: REPLACED CAM SENSOR
1FTNW21F3YEE01270 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 30-MAY-2000 15-JUN-2000 123002 USA 93 * * * * * * * 83924
AWS Claim Key: 26042477 Trx Code: 07S57 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 06414 - * Name: CROSSROADS FORD Ph: 901-7626500 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:24-JAN-2008 Doc #:01746803
Cust Comments: 07S57 CAM SENSOR RECALL
1FTNW21F3YEE01270 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 30-MAY-2000 15-JUN-2000 123002 USA 115 * * * * * * * 97002
AWS Claim Key: 26725792 Trx Code: 09S09 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 06000 - * Name: COUNTRY FORD, INC. Ph: 662-3494300 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:10-NOV-2009 Doc #:234475A
Cust Comments: SPEED CONTROL SYSTEM MODIFICATION
Tech Comments: PERFORM RECALL 09S09B
Reactions: 363coupe
Thanks alot. It looks like it might be a decent truck other than the ABS LOL
I really appreciate you doing that.
