When did dodge start putting the lift pumps in the tank from the factory?
I'm pretty sure in 2003...
Also in 2003 they where retro fitting the intank pumps for 1998.5 to 2002...
I think the in tank pump is a corporate solution to problem that causes another problem. I have 2 friends that did this factory mod both have low fuel pressure still. And now want to replace the intank pump with a FASS system. Save your money get a aftermarket fuel system and larger lines and all with be well.
:iagree
So very true...
The reason I was asking is that I have a new vp44 and a fass on the way. I work a 2 week on 2week off schedule so I wanted to make sure I had every thing when I get home.
Just a suggestion. Don't forget the larger fuel lines and the fittings to get rid of the banjo fittings. Good luck on your up grade to the fuel system.
