beware the dark side
I am trying to measure the inducer size on my turbo so i can determine what class i will be pullin in. I believe it is the area marked inside the turbo where you can see the vains but i am not sure. can not get my picture to load that would make this alot easier.
The one and only
If your running a stock turbo you are 2.6 i believe
sorry i have not had time to update my sig yet. I am running a turbonetics ball bearing drop in turbo. Thats why i am trying to determine the inducer size for the local pulls.
The one and only
I think that is a 2.6 but im not sure.
i measured the diameter where if you are looking into the inlet of the turbo the impeller wheel is and it measured at 2.6 inches so i figure it is a 2.6 turbo but i just wanted to make sure before i argue that it is if one of the guys at a pull says otherwise.
