Supporting Vendor
Supporting Vendor
Bump, where are all the big bad Cummins guys at?
I'm seriously looking into this pump. Does it simply work on/off with the ignition system, or can I switch it on/off if I figure out a custom wiring job with this Davies Craig controller. Is this the same unit that EnterpriseEngine.com carries?
What serpentine belt do you use after its installed? I'd like to keep my a/c.
Supporting Vendor
Same pump, we can supply you the correct part number for the belt. We run them on a switch so after a pull or drag race you can keep the pump on to help cool down the motor quicker.
Dave
