When i install a new set of injectors, dont i need to do a valve adjustment?
do you need it....i don't think so, but its a great time and a good idea
2nd Gen Guru
Since you got the valve cover off why not... Just a extra hour to adjust the valves...:poke:
to change the injectors u have to take the valve bridges off and to do that u have to back the valves off so unless you are good at guessing then you will have to reset them.
i think?
You don't have to touch the valves when doing an injector swap. However, it would be a good opportunity if you are over 115K miles and have never done it.
