1 - 10 of 10 Posts
4
I finally got around to getting the regulated return kit installed on my truck. Go to this page to see the details of whats involved in installing this kit.
Dave
TDG MAFIA MEMBER #71
Has anyone else did this mod and if so have you seen the same results? Do you guys recommended this mod? Any info would be greatly appreciated.
I have not done it yet, but it is one of the best mods for these trucks! I am working on building my own set up deleting the whole fuel bowl...
Are you going to run a after market filter in its place? Do you think yours will be cheaper to build?
I dont know if it will be cheaper, but I want to delete the fuel bowl so I can run about 100PSI fuel pressure without blowing the top off. Someone on here did one on a OBS truck that I am kinda copying... I think the user name is racehauler???
Let me know how it turns out.
What will be the benifit of running 100psi?..give us the scoop!
Not sure, but the only reason I dont do it now is due to the factory fuel bowl will blow the top at 100psi sometimes...
4
I was under the impression Joe that anything over about 80psi fuel pressure really makes a racket with the injectors. Unless you are going to firehose sized injectors...
LOL there already BIG... Going to run Two SD pumps too... We will see. I just know at this point I can suck them down to 50#'s on a hard run...
1 - 10 of 10 Posts
