This is on a '99 Dodge. Every once in a while, when I start it, I have NO guages (fuel, tach, oil, speedo, nothing), most of the idiot lights stay on, and after a few seconds the odometer reads "NO BUS". But it seems to run fine. If it sits for a while, everything starts working again, and after a few cycles, the CEL goes out. Anyone run across this one before? The dash panel has been out once or twice for various reasons, and it acts like a bad connection on something, but I can't find it?
********* and Mafia #90
read the cell when it comes up.
also the cel is a hard code, have the truck scanned with a good scanner, it should pull soft codes and point you in the right direction.
2nd Gen Guru
You need to check for error codes...
http://mopar.mopar1973man.com/tips/cummins/2ndgen24v/obd2-error-codes/obd2-error-codes.htm
Then as for the NO BUS error you might read up on the CCD network...
http://mopar.mopar1973man.com/tips/cummins/general/ccd/ccd.htm
Also try the cluster testing...
http://mopar.mopar1973man.com/tips/cummins/2ndgen24v/cluster-test/cluster_test.htm
