I am wondering what the internal limits of our 24valve's before we start blowing head gaskets, needing head studs, etc...
Is it somewhat reliable to get to 450 hp with out having to do internal mods?
B
Yes! Although anything can happen at anytime when you go past stock.
I understand that the maximum boost pressure is 45 pounds and after that you begin to risk blowing the head gasket.
I think Cummins was quoted on saying something like 52 PSI actually.
I know that a cummins with no studs can go with about 55 to 60 psi.. I was pulling this with no studs.. But I went ahead and got the studs anyway
Try doing that on a stock powerstroke or duramax.
Sounds pretty damn good to me, 450 is my target number eventually, just trying to work out any unexpected and expected problems
yeah 450 shouldn't be an issue. I've seen quite a few 24v's running 50-55psi without headgasket problems but I think you're pushing it at that level. But like bill said, anytime you go above stock you start running risks. bumping the timing alot or running water/meth or propane will blow your head gasket in a hurry though, so try to do it on fuel only.
sean
