1 - 20 of 22 Posts
i bought a turbo from a junk yard is it to big for me this is on the tag
assy 3519095
serial 1220652
type h2c
holset
out side intake is 4 inchess
inside is 2 1/2
exhaust side 4 inside for the down pipe
3 inch to the intake
i have a 354 perkins in a 1948 kb5
No it is not too big, I do not recall if a h2c is about the same size as a HX40 or HX35, either way it could work.
Why not just go with a HX35 or HX40?
On your exhaust manifold do you have a T3 or T4 outlet?
Hot Rod Farm Boy
H1C is like a HX35, H1E is like a HX40.
H2C is a 62/75/18. It's not too large, what are you planning on doing with it? I'd say it could support 500-550hp but it would be mostly mid to top end power.
it is going on my 1948 kb5 it has a 354 perkins with a 5spd overdrive with .80 overdrive it is 4 wheel drive with 3.73 gears dont do to much pulling my perkins has no turbo i have to make a plate for it
gone fishin!
i would say the h2 will be real doggy for ya, if i remember the 354 is indirect injection so if you toss fuel at it to light the big turbo... its just gona get hot before it will do anything, i would hunt for a s-300 size frame under 60/70......... you need a tighter exhaust to deal with egts down low and a big gate to deal with egts up top.....
Could you post a picture of your exhaust maniflold outlet. I am not sure what horse power range you are wanting to go ... I have a small turbo new just sitting around it has a T4 turbine inlet and a V band outlet and flows 37 lbs of air that is not much but should support 300 HP easy and spool quick. I would let it go for 200 + the trip. Let me know if it will help you other wise I am selling it on Ebay.
gone fishin!
dt360 should have a pretty tight s-300 on it... i would go with that before the h2.
gone fishin!
its a slim shot but you might be able to bolt a WG hx40 hot side onto the h2.......they have a 16cm3 with a t-3 foot and 3" outlet..... might be a little surgey but would light down low and flow at the top.
Discussion Starter #13
just be better to get a smaller one sale this one if i can and get a smaller one make it more sence
I am do not know what you want to make for Horsepower but why not pickup a good HX35? There are a lot around with T-3 foot. Shoot you could even find a WH1C. Those are common and easy to find parts for.
Hot Rod Farm Boy
He would have to get the 40 housing machined to fit that 75mm turbine.
gone fishin!
yea thats true..... i forgot it was 75.
Hot Rod Farm Boy
I've seen those chargers before, heard good things about them. There's a guy with the username TURBOLVR that ran three of them set up with two feeding into one and he used them pretty hard. I find it hard to believe that one of those could support 800hp like they say though LOL
1 - 20 of 22 Posts
