Discussion Starter · #1 · (Edited)
I have a 1999 International 4700 LP with a 8.7L and Allison 6 spd. It is used as an RV hauler, but sets often because we are full-timers in the same location. I use it occassionally just to move things around and move an rv for someone. The left rear caliper started sticking about 2 months ago. I took it to my diesel mechanic and I told him to do a complete rear brake job. He did. It sill has the problem. Specifically, I will start up and the brakes are fine. I drive for about 20 minutes and start loosing brake pressure. e.g. brake pedal goes half way to the floor before pressure stops the truck. If I pump the pedal it comes back, but the caliper is now hot from sticking and I take it home to cool it off. I work on all my vehicles but my International, but my mechanic is unavailable for 3 weeks. Any suspects of why it does this? Any remidies? Thank you.
Curtis
What consists of the “brake job”? Just rotors and pads or did he address the caliper sticking issue? Reman’d calipers are 100 bucks from the dealer I would do both. The brake booster is electric, so I would look at that, perhaps you need a new booster, new motor, or even the solenoid could be failing. I’d start by replacing the solenoid. And go from there...
Sent from my iPhone using Tapatalk
Discussion Starter · #4 ·
I agree with @JWT4700 that the brake job was probably just pads. I'd call and ask.
The rear brake job consisted of pads, rotors, and new (not refurbished) calipers. Then I did the front brakes the same because the sticking persisted. I am also going to change the “auxiliary pump” relay. Then we will see from there.
What were the results after changing the relay? Did it solve the problem?
