why would you want to do that?
If you do that running some fueling boxes, it will give you full fuel at zero boost. It makes a lot of smoke. You will probably throw all kinds of codes and have your power disappear on you if you aren't running a box.
2nd Gen Guru
dodgetheonlytrk said:
i have a question i have seen people disconnect there map sensor is that ok thanks
I've got a write up on the this at the link below... (Towards the bottom)...
http://mopar.mopar1973man.com/2002-dodge/bombs/edge-comp/edge_comp.htm
But remember anytime you see black clouds that means your watching your unburn fuel, wasted money and reduced MPG happen... Nice for shows but not worth it for daily driving...
