Standard Claims List For Model Year 2003
1FTNW21P03EC68811 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-MAR-2003 03-MAY-2003 152057 USA 10 7S08 180101 * 14305 * L26 28 22532
AWS Claim Key: 4500671 Trx Code: E83 Labor Hrs: 2.1
Dlr Cd-Sub Cd: 04545 - * Name: MCCOMBS FORD WEST Ph: 210-5091000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:03-FEB-2004 Doc #:06184953
Cust Comments: CUST STATES RT TURN SIGNAL INDICATOR STAYS ON
Tech Comments: OPEN CIRCUT R&I STEERING COLUMN TO REPAIR CIRCUT 16 WHT LT BLUECOONECTOR 2026
1FTNW21P03EC68811 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-MAR-2003 03-MAY-2003 152057 USA 10 7S22 180106 D9ZZ 14526 D A85 42 22532
AWS Claim Key: 4483052 Trx Code: S07 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04545 - * Name: MCCOMBS FORD WEST Ph: 210-5091000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:03-FEB-2004 Doc #:06184954
Cust Comments: CUST STATES POWER POINT INOP.
Tech Comments: FUSE REPLACED FUSE
1FTNW21P03EC68811 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-MAR-2003 03-MAY-2003 152057 USA 10 7S02 180102 * 14401 * L26 28 22532
AWS Claim Key: 4500670 Trx Code: E83 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 04545 - * Name: MCCOMBS FORD WEST Ph: 210-5091000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:03-FEB-2004 Doc #:06184951
Cust Comments: CUST STATES RT HEADLITE IS DIM
Tech Comments: OPEN CIRCUT REPAIRED OPEN CIRCUT G108
1FTNW21P03EC68811 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-MAR-2003 03-MAY-2003 152057 USA 10 7F06 0116XX * 17603 * W03 42 22532
AWS Claim Key: 4483051 Trx Code: E83 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 04545 - * Name: MCCOMBS FORD WEST Ph: 210-5091000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:03-FEB-2004 Doc #:06184952
Cust Comments: CUST STATES WINDSHIELD WASHERS ARE INOP.
Tech Comments: VACUUM HOSE R&I INNER FENDER WELL TO REPAIR VCUUM HOSE.
1FTNW21P03EC68811 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-MAR-2003 03-MAY-2003 152057 USA 44 * * * * * * * 89610
AWS Claim Key: 14623034 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04410 - * Name: NORTHSIDE FORD Ph: 210-5259800 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-NOV-2006 Doc #:52795204
Cust Comments: A99 59B01 ONE TIME CUST ASSURANCE TEST DRIVE
Tech Comments: ROAD TEST VEHICLE PER 59B01 FSA
AWS Claim Key: 14623033 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 04410 - * Name: NORTHSIDE FORD Ph: 210-5259800 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-NOV-2006 Doc #:52795205
Cust Comments: A99 04S15 NEGATIVE BATTERY TERMINAL TO ENG BLOCK CONNECTION
Tech Comments: 1 PERFORM 04S15 BATTERY TERMINAL RECALL.
AWS Claim Key: 14623035 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04410 - * Name: NORTHSIDE FORD Ph: 210-5259800 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-NOV-2006 Doc #:52795203
Cust Comments: A99 06E17 CONTROL MOD RECALIBRATION
Tech Comments: PERFORM 06E17 RECAL RECALL
Reactions: poolman800
1FTNW21P23ED64214 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-JUN-2003 06-AUG-2003 152729 USA 0 6Y05 000001 * TDRIVE * A96 82 5
AWS Claim Key: 2191098 Trx Code: R7U Labor Hrs: 0.4
Dlr Cd-Sub Cd: 04466 - * Name: BOGGUS FORD Ph: 956-4232580 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:01-JUL-2003 Doc #:07934951
Cust Comments: TEST DRIVE6.0
Tech Comments: TEST DROVE TEST DRIVE 6.0
1FTNW21P23ED64214 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-JUN-2003 06-AUG-2003 152729 USA 25 6E01 011001 3C3Z 2560136 CAA B94 34 31518
AWS Claim Key: 11766073 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:17-AUG-2005 Doc #:05302356
Cust Comments: CENTER CONSOLE IS PEELING DOWN (HAS TAPE ON DRIVERS SIDE)
Tech Comments: ACES CODE:pAAKN REPLACED CENTER CONSOLE
1FTNW21P23ED64214 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-JUN-2003 06-AUG-2003 152729 USA 25 5C02 050100 * 4602 * C50 42 31518
AWS Claim Key: 11766070 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:17-AUG-2005 Doc #:05302353
Cust Comments: POPS INTO GEAR WHEN YOU FIRST TAKE OFF IN DRIVE (2 DIFFERENT NOISES BOTH IN REAR)HAPPENS AT TAKE OFF NOT LIGHT ACCEL
Tech Comments: NOISEY R R DRIVESHAFT TO LUBE SLIPE YOKE W TEFLON GREASE
1FTNW21P23ED64214 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-JUN-2003 06-AUG-2003 152729 USA 25 1H03 030008 4C3Z 9F452 A D50 42 31518
AWS Claim Key: 11766071 Trx Code: S07 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:17-AUG-2005 Doc #:05302354
Cust Comments: LACK OF PWR SEEMS TO BACKFIRE THRU EXHAUST HUGE PUFFS OF BLACK SMOKE FROM EXHAUST&LOTS OF SUT ON TAIL PIPE POOR FUEL MILEAGE EXHAUST FUMES N CAB
Tech Comments: INOP ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
1FTNW21P23ED64214 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-JUN-2003 06-AUG-2003 152729 USA 25 7H01 120301 * 19703 * C01 42 31518
AWS Claim Key: 11766072 Trx Code: E83 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:17-AUG-2005 Doc #:05302355
Cust Comments: AC CUTS IN & OUT (COMPRESSOR CUTS OFF & THEN BACK ON)
Tech Comments: INOP PRESSURIZE, LEAK TEST, DISCHARGE, EVACUATE AND CHARGE AIR CO
1FTNW21P23ED64214 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-JUN-2003 06-AUG-2003 152729 USA 25 6P07 011404 * 2822008 * L06 07 31518
AWS Claim Key: 11778775 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:17-AUG-2005 Doc #:05302357
Cust Comments: DR FT DOOR BOUNCES TO SHUT (DOESNT HAPPEN TO OTHER DOORS)
Tech Comments: IMPROPERLY ADJUSTED PLATE DOOR LOCK STRIKER ADJUSTED
1FTNW21P23ED64214 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-JUN-2003 06-AUG-2003 152729 USA 32 3A04 070102 3C3Z 7J136 AA P59 42 60292
AWS Claim Key: 13280962 Trx Code: P05 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:06-MAR-2006 Doc #:07683351
Cust Comments: TRANS DOES NOT STAY IN THIRD GEAR SHIFTS IN AND OUT AND O D LIGHT IS FLASHING ADVISE
Tech Comments: TEST AND VERIFIRED CONCERN TRANS DIAG P0730FF, P2703FF, PERFORMED PIN POINT TEST AND ACCESS PAN AND REPLACE DIRECT CLUTCH SOLENOID, CLEAN & REUSE PAN GASKET, FILLED W FLUID, REPROGRAMMED PCM, FICM, TCM, TO LATSET LEVEL AND PERFORMED ADAPTIVE STRATEGY, RD TEST OK
1FTNW21P23ED64214 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-JUN-2003 06-AUG-2003 152729 USA 32 * * * * * * * 60292
AWS Claim Key: 13280964 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:06-MAR-2006 Doc #:07683354
Cust Comments: RECALL#59B01 ONE TIME TEST DRIVE
Tech Comments: RECALL 59B01 59B01
AWS Claim Key: 13280963 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:06-MAR-2006 Doc #:07683353
Cust Comments: RECALL#06E17 CONTROL MOD. UPDATE
Tech Comments: RECALL 06E17 06E17
1FTNW21P23ED64214 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-JUN-2003 06-AUG-2003 152729 USA 42 5V01 050301 3C3Z 1104 BA D02 42 98344
AWS Claim Key: 14781969 Trx Code: P01 Labor Hrs: 4.5
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:02-JAN-2007 Doc #:02359451
Cust Comments: CHECK HUBS HAVE EXCESSIVE NOISE WHILE DRIVING REPORT FRONT END HAS PLAY P01 PER SERVICE MANAGER
Tech Comments: NOTE: FRONT TIRES CUPPED AND NOISY
1FTNW21P23ED64214 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-JUN-2003 06-AUG-2003 152729 USA 42 2E01 030008 3C3Z 9F838 EA D02 D1 98344
AWS Claim Key: 14770064 Trx Code: E72 Labor Hrs: 5.2
Dlr Cd-Sub Cd: 04546 - * Name: JORDAN FORD, LTD. Ph: 210-6533673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:02-JAN-2007 Doc #:02359452
Cust Comments: 6.0L DIESEL HAS NO POWER ON ACCELERATION AND ENGINE LEAKS OIL REPORT
Tech Comments: OIL LEAK VERIFIED CONCERN CKD OASIS FOR SYMPTOM PREL CK OK RD TESTED MONITORED PIDS FOUND ICP VOLTAGE LOW REMOVED HEAT SHIELD AT REAR OF ENGINE FOUND OIL LEAKING THROUGH ICP SENSOR REPLACED ICP SENSOR & CONNECTOR RD TESTED MONITOR PIDS EEC TEST ALL SYSTEMS OK AT THIS TIME INSTALLED OIL DYE IN ENGINE TEST DROVE CKD WITH BLACK LIGHT FOUND OIL LEAKING FROM HOT SIDE CAC
