Thanks Idahofox and Rick for the info on the LB7 turbo on the LLY.
LB7 on LLY This is the kind of thing we should be talking about.
Hmmmmmm.........Fingers said:The IHI <> VVT swap should be interesting. Rick and I both expect a performance drop since the VVT does generate more/better boost across the rev range.
FWIW the VVT generates huge amounts of drive pressure compared to the IHI. For instance, at 20 PSI of boost, the IHI drive pressure is about 25 PSI and the VVT is over 40 PSI. At 30 PSI of boost, the IHI is around 40 PSI but the VVT is close to 70 PSI.
On the 6.6 Dmax, each PSI of backpressure costs about 2 HP in strictly mechanical terms. So by reducing the VVT's drive pressure to be 1/2 way closer to the IHI you could easily find 30 HP. That 30 HP, BTW, is equiv to about 1200 BTU/min.
:damnitkillerbee said:Jon
What is your estimation then of parasitic HP loss to the VV turbo?
Whats the timeframe looking like?Fingers said:That's all the theory. I'm looking forward to the results from the swap. It will give me confidence to push forward with the vane redesign if it works.
All true, except the design of the head still comes into play as you must take into account the cylinder firing pressure.Turbotug said:originally posted by TxC..
GM releases say that they increased the flow of coolant through the heads looking for more cooling, going off that we have long thought they didn't open them up enough to deal with the new heat they knew they had coming. The LBZ has new heads yet again. Be aware too that the heads also determine compression, and that the exhaust ports are the largest source of heat in any engine, and are always completely water jacketed. They are the easiest place to screw up. Its happened before. Many a cylinder head has been ruined by removing too much material when porting or casting and resulting in either cracked seats are a chronic overheat problem.
I was under the impression that the bowl in the piston, piston protrusion, and headgasket thickness determined compression ratio. The head surface/valve area looks to be flat and does not have a compression chamber like a gasser. DMAX head in cnc lathe
TxChristopher said:All true, except the design of the head still comes into play as you must take into account the cylinder firing pressure.
What is this Please ? :shrug:TxChristopher said:All true, except the design of the head still comes into play as you must take into account the cylinder firing pressure.
Hi Chris:TxChristopher said:All true, except the design of the head still comes into play as you must take into account the cylinder firing pressure.
You, sir, would be correct. The cylinder area on the Dmax head is flat, save for the valves. The bowl in the piston is the chamber.Turbotug said:I was under the impression that the bowl in the piston, piston protrusion, and headgasket thickness determined compression ratio. The head surface/valve area looks to be flat and does not have a compression chamber like a gasser. DMAX head in cnc latheTxChristopher said:GM releases say that they increased the flow of coolant through the heads looking for more cooling, going off that we have long thought they didn't open them up enough to deal with the new heat they knew they had coming. The LBZ has new heads yet again. Be aware too that the heads also determine compression, and that the exhaust ports are the largest source of heat in any engine, and are always completely water jacketed. They are the easiest place to screw up. Its happened before. Many a cylinder head has been ruined by removing too much material when porting or casting and resulting in either cracked seats are a chronic overheat problem.
I am still fumbling over this statement. It implies that that over 60 HP must be dedicated to the VVT to spin it.Fingers said:On the 6.6 Dmax, each PSI of backpressure costs about 2 HP in strictly mechanical terms. So by reducing the VVT's drive pressure to be 1/2 way closer to the IHI you could easily find 30 HP.
No problem Tom. I don't do it for the fame anyway.TheBac said:Jon, you have my apologies if I spoke out of turn on your experiment. I think its the best idea I've heard in a long time, and couldn't wait to tell the membership.
I called it scavanging, but the same thing.Diesel Tech said:Jon
How about the internal EGR affect?
The turbo, in it's "free lunch" aspect, is driven by exhaust, a waste product (expanding exhaust gases that have left the cylinder), so it is not tapping power from the motor, at least not like a parasitic device, alternator for example.Fingers said:I called it scavanging, but the same thing.
Also, I would like to correct the pure mechanical HP loss at 2800 is 1.4239 HP/PSI of drive pressure. I rounded WAY up. My fault. Still significant.
A turbocharger is not a free lunch. Never was. The engine has to fight the backpressure to get the exhaust through the turbo, That takes WORK. Work over time is POWER. The nice thing about turbos has been they only consume power in pace with the work they do. Very one for one as apposed to the constant drag of a direct drive supercharger. The "better" the turbo, the better the ratio between the drive pressure and the boost.killerbee said:The turbo, in it's "free lunch" aspect, is driven by exhaust, a waste product (expanding exhaust gases that have left the cylinder), so it is not tapping power from the motor, at least not like a parasitic device, alternator for example.
This is where I am not seeing a benefit, but I am trying.:Thumbup: My limited forced induction knowledge is showing.
Are you saying that excessive turbo backpressure is causing less expansion (thus less work performed) in the cylinder? For that to be the case, drive pressure would have to be significant (vs negligible) compared to cylinder pressures.
