CRAZY CANUCK
IIRC the dmax in the 06 vans are strictly LLY, and i believe they are de-rated to 280 or 290hp...
Super Moderator
Look on the VIN for the 8th digit for engine ID.
1 - LB7 (2001-2004.5)
2 - LLY (2004.5-05)
D - LLY/LBZ [note: The LLY of these years is actually an LBZ with different tuning. So check the build date (IIRC on the drivers door) before you buy. IIRC, the switch was in Jan of 2006.]
6 - LMM
Allison trannys were 5 speeds 2001-2005. 2006-up are 6 speeds with tap shift.
Sticky in General GM truck section
