Vendor
CARR Hoop Step Comparison/Review - YouTube
When you need an easy way to get in and out of your Chevy truck, but don't want to lose the vital clearance by installing the cab-length side steps, then individual Hoop Steps by CARR would be the best solution!
Although they are smaller, than full-length sidebars, they're just as much convenient. They are designed to ease the access to the cab for you and your passengers. We took two of the most popular CARR Hoop Steps models and compared them in our new video review.
CARR® - LD Hoop Steps at CARiD.com
Features:
- 15” width
- Aggressive and appealing tread design for a non-slip surface
- Flat step area for increased safety
- Tough construction to hold up under extreme conditions
- Made of rust-resistant cast aluminum alloy
- Exclusive Multi-Mount system with rotating mounting heads for a snug fit
- Mounting system made of zinc-plated steel for superior strength
- Easy installation with only minor drilling.
CARR® - Super Hoop Steps at CARiD.com
Features:
- Length: 20""
- Step Pad: Exclusive diamond non-slip tread pattern
- Weight Capacity: 350 lbs per step
- Come available in 3 sizzling finishes: Black, Titanium Silver, and Polished
- Exclusive new multi-mount system
- Made of corrosion resistant, durable cast aluminum alloy
- Rugged tread pattern provides for safe and attractive non-slip surface
- Rocker panel installation provides for the strongest and easiest installation of any step products.
View all CARR Light Bars, Hoop Steps, Truck Accessories at CARiD.com
Carr Hoop Step is a stylish and affordable solution for every truck. If you have any questions or need a price quote, reach me directly in PM or comments below.​
