just got back from 2600 mile trip while driving once in a while i would get this faint whiff of anti freeze kept checking no apparent loss of a/f . still no apparent loss of a/f .now when i start the truck in the morning and let it run for about 5 mins it leaks about a 1/4 cup of a/f drive it 16 miles home and no leak i. it seems to be leaking at the front of the head drivers side, behind the vac pump there is what i assume to be power steering lines and an allen plug with red sealant on it it. it is running around the plug like its comming from above that spot, it could be the plug as well . has anybody had this leak or know where it is leaking???:thanks: kirk
it may be from your waterpump weep hole. look under your truck with a flashight at the pumps weep hole, any signs of antifreeze ?? i replaced one like this. the fan was blowing it up their. pressure up the coolant system it my help find it.
