Hi,the pipe that goes from the EGR cooler to the top of pasenger side up pipe started to leak at the flex joint,just wondering if any body was able to change it whitout lifting the cab,could not take it off,so i cut it,din try to install the new one yet,my question is,what if i just cut the old one after the section after the flange on up pipe side and weld a plate and install the EBP sensor in it,would that work,i did try runing it whit just a block off plate and left the sensor plug in,just to get home,my bost was all the way up at low speed,so my guess that it does need that sensor to run,just trying to find an easy fix,did delete the cooler and DPF already.
Powered By Ford
its a common problem, I believe its a cab off only procedure but am not sure, itll happen again, only a matter of time, just get the 6.0 manifolds and up pipes and be done with it
