Just put led 3157 bulbs in the front of my 2010 from what I have read the turn signal controled by one of the computers. Is there away around making the turn signals flash correctly with out wiring in those resistors.
nope the led draws less power so the light thinks the buld is going out so it blinks faster the resistors are cheap
I figured, just didn't want to cut into the wiring
FukeneH
same problem was thinking about finding the flasher and putting an LED flasher from KW in, you say signals are controled by ECU on are trucks?
From what i understand yes. I have the led flasher for the 07 and older trucks. I did a little research and the ecu controls them from what i read. I did this to my 07 and it workered great
