1 - 10 of 10 Posts
My interior dome light is staying on and my "Door Ajar" light is staying on in my 1999. What can I do to fix this problem? My next question is the cargo lights bulbs are out, does this have anything to do with the dash light staying on?
Mafia Member #93
Spray some WD-40 in all the door latches, it workes every time!
I did that earlier in the night and the light still stays on. I sprayed the latch in the door and on the door jam. Anything else that I need to do?
There's a door switch acting up. If spraying lube into all the door latches and open/ closing them multiple times doesnt help, then you'll need to figure out which switch it is and replace it. The only way I can think of doing that would be to unplug them one at a time and see when the light goes out.
How would I do that? Where are the switches located?
Slow 6.0
they are located in the outside door latches, u have to take the door panel off to get to the switch.
I've got the same problem starting today and was searching for some help. Light on dash stays on as if a door is open and dome light stays on. I'll try the WD-40 as a first step.
:givemebeer
Thanks again to this forum for another quick fix to an otherwise evasive problem. I tried the WD-40 and no more problem.
This site is great.
I have the same problem just never got around making a thread. Going to try this today.
Thanks,
Brendon
1 - 10 of 10 Posts
