We all know Fords limited slip is a piece. Mine has never worked. Do you guys think if I add a friction modifier, it will help at all? thanks
Nope. Friction modifier will REDUCE friction. You can try changing the fluid and NOT adding any modifier back in. More adventurous is to add shims or change the plate sequence to increase friction. The ultimate answer is to switch out the gears for a locker. I've changed the fluid in mine and put Royal Purple back in with no modifier and haven't really been able to test it in snow yet but seems to have helped some from what I've seen on wet grass.Silver6.0 said:We all know Fords limited slip is a piece. Mine has never worked. Do you guys think if I add a friction modifier, it will help at all? thanks
