I have a 11 SD 4x4 with auto locking hubs - you turn the dial in the truck and the four wheel drive engages automatically. Since everyhing is managed from the cab, why do the wheels have 'auto' and 'lock' hubs that you can manually engage ? It was the same on my old 06 SD.
Never have had to use the manual system, but Im assuming it's there as a back up, or redundant system in case the automatic locking malfunctions ? Is this correct - if so, is it as simple as just turning the hub to 'lock' or do you have to activate it from the cab too ?
Just curious.
Thanks
Just curious.
Thanks
