Standard Claims List For Model Year 2000
1FMNU42F7YEE15247 T/L1 F T/WD T/CA T/B A1 T/D8 T/DS 02-JUN-2000 21-SEP-2000 124550 USA 2 7S02 180102 * 14401 * L29 42 4651
AWS Claim Key: 4671293 Trx Code: 1 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00848 - * Name: ORVILLE BECKFORD FORD-MERCURY Ph: 850-6232234 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:23-OCT-2000 Doc #:09464652
Cust Comments: LIGHT ON DRIVERS SIDE RUNNING BOARD INOP
Tech Comments: CHECK ELEC LOOSE CONNECT PP TEST REPAIR WIRING
1FMNU42F7YEE15247 T/L1 F T/WD T/CA T/B A1 T/D8 T/DS 02-JUN-2000 21-SEP-2000 124550 USA 2 2H01 030008 * 6K682 * N12 33 4651
AWS Claim Key: 3880804 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 00848 - * Name: ORVILLE BECKFORD FORD-MERCURY Ph: 850-6232234 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:23-OCT-2000 Doc #:09464651
Cust Comments: POP AND THEN NO POWER
Tech Comments: LOOSE BOOST PRESSURE TEST REINSTALL TURBO INLET TUBE
1FMNU42F7YEE15247 T/L1 F T/WD T/CA T/B A1 T/D8 T/DS 02-JUN-2000 21-SEP-2000 124550 USA 7 6Y20 010805 YC3Z 18246 AA A98 41 15920
AWS Claim Key: 7539864 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 00848 - * Name: ORVILLE BECKFORD FORD-MERCURY Ph: 850-6232234 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:09-APR-2001 Doc #:00034053
Cust Comments: VENT SHADE ON RIGHT REAR CAME OFF GOING DOWN THE HIGHWAY
Tech Comments: LOOSE REINSTALL VENTSHADES
1FMNU42F7YEE15247 T/L1 F T/WD T/CA T/B A1 T/D8 T/DS 02-JUN-2000 21-SEP-2000 124550 USA 7 6N01 010805 YC3Z 7829164 AAB B63 33 15920
AWS Claim Key: 7539862 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: 00848 - * Name: ORVILLE BECKFORD FORD-MERCURY Ph: 850-6232234 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:09-APR-2001 Doc #:00034051
Cust Comments: TRIM AROUND RIGHT REAR WHEEL OPEN COMING LOOSE
Tech Comments: LOOSE TRIM SENT TO BODY SHOP TO INSTALL MOLDING
1FMNU42F7YEE15247 T/L1 F T/WD T/CA T/B A1 T/D8 T/DS 02-JUN-2000 21-SEP-2000 124550 USA 7 6L05 011201 YC3Z 2513560 CAA T50 01 15920
AWS Claim Key: 7539863 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00848 - * Name: ORVILLE BECKFORD FORD-MERCURY Ph: 850-6232234 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:09-APR-2001 Doc #:00034052
Cust Comments: CUP HOLDER IN DASH WON;T HOLD ON LEFT SIDE
Tech Comments: BROKEN REPLACE CUPHOLDER
1FMNU42F7YEE15247 T/L1 F T/WD T/CA T/B A1 T/D8 T/DS 02-JUN-2000 21-SEP-2000 124550 USA 11 3B01 070202 YC3Z 7C410 AB L65 D8 25548
AWS Claim Key: 10235953 Trx Code: E84 Labor Hrs: 2
Dlr Cd-Sub Cd: 00848 - * Name: ORVILLE BECKFORD FORD-MERCURY Ph: 850-6232234 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:06-AUG-2001 Doc #:00476952
Cust Comments: CHECK OIL LEAK AT RADIATOR
Tech Comments: LEAKING OIL LEAK CK AND REPLACED TRANS COOLER LINES
1FMNU42F7YEE15247 T/L1 F T/WD T/CA T/B A1 T/D8 T/DS 02-JUN-2000 21-SEP-2000 124550 USA 15 * * * * * * * 34906
AWS Claim Key: 13504089 Trx Code: 01S24 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 00848 - * Name: ORVILLE BECKFORD FORD-MERCURY Ph: 850-6232234 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:12-DEC-2001 Doc #:00955951
Cust Comments: 01S24 RECALL WIPER MOTOR GEAR COVER
Tech Comments: 01S24 RECALL 01S24 PERFORMED RECALL
1FMNU42F7YEE15247 T/L1 F T/WD T/CA T/B A1 T/D8 T/DS 02-JUN-2000 21-SEP-2000 124550 USA 15 1A03 030101 * 6007 * D21 42 34906
AWS Claim Key: 13504091 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00848 - * Name: ORVILLE BECKFORD FORD-MERCURY Ph: 850-6232234 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:12-DEC-2001 Doc #:00955953
Cust Comments: CUSTOMER STATES FIRST THING IN THE MORNING IF YOU PUT THE TRUCK IN REVERSE IT SPUTTERS AND ALMOST GOES DEAD UNLESS YOU KEEP YOUR FOOT ON THE GAS
Tech Comments: NO PROBLEM FOUND ENGINE PERFORMANCE DIAGNOSTICS 7.3L DI TURBO ENGINE DIAG
1FMNU42F7YEE15247 T/L1 F T/WD T/CA T/B A1 T/D8 T/DS 02-JUN-2000 21-SEP-2000 124550 USA 15 3A11 070100 * 7000 * L73 42 34906
AWS Claim Key: 13504090 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 00848 - * Name: ORVILLE BECKFORD FORD-MERCURY Ph: 850-6232234 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:12-DEC-2001 Doc #:00955952
Cust Comments: CUSTOMER STATES HE HAS A TRANSMISSION LEAK, IT IS LEAVING SPOTS ON THE GROUND
Tech Comments: NO PROBLEM FOUND OIL LEAKS AUTOMATIC TRANSMISSION DIAGNOSIS
1FMNU42F7YEE15247 T/L1 F T/WD T/CA T/B A1 T/D8 T/DS 02-JUN-2000 21-SEP-2000 124550 USA 24 2A01 031201 1C3Z 9601 AA D50 42 52545
AWS Claim Key: 18334490 Trx Code: 0798D Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00848 - * Name: ORVILLE BECKFORD FORD-MERCURY Ph: 850-6232234 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:15-AUG-2002 Doc #:01761251
Cust Comments: CUST STATES TURBO LEAKING CK AND ADVISE
Tech Comments: AIR FILTER REPLACE AIR FILTER
1FMNU42F7YEE15247 T/L1 F T/WD T/CA T/B A1 T/D8 T/DS 02-JUN-2000 21-SEP-2000 124550 USA 106 * * * * * * * 139302
AWS Claim Key: 26614225 Trx Code: 07S57 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04962 - * Name: WORLD FORD-PENSACOLA Ph: 850-4769050 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:28-MAY-2009 Doc #:110949D
Cust Comments: CAMSHAFT POSITION (CMP) SENSOR INSPECTION REPLACEMENT
Tech Comments: 139303 RECALL INSPECT AND REPLACE CAM SENSOR
has the speed control recall open. 09s09
7.3 addict
If the price is right jump on it! hard to go wrong on a 7.3.
